Article:
http://hackaday.com/2016/03/21/just-whe ... echanisms/
Video:
https://youtu.be/IANBoybVApQ
This is insanely cool
Seeing as it's a brand new technology, I'm sure it is super duper patented.TheRealRocketBurns wrote:I would love to see if someone designs a reprap one, maybe as an extruder you could put on to an existing printer.
The funny thing is, I intended to printer to be interpreted as a normal 2D printer, not a 3D printer.626Pilot wrote:Magnets are normally polarized by running huge amounts of current through them.
If I'm right, this is not a "magnetic 3D printer" so much as a Cartesian robot that places an anode and cathode on the top and bottom of the magnet, and then juices the hell out of a very small area at any one time. The direction of current flow would dictate the direction of the iron atoms. However, I would expect to see significant "bleeding" of current through the surrounding metal, blurring the "maxels."
It could be that instead of that, they're using powerful electromagnets that generate a tightly confined, very narrow and vertical EM field that passes through the magnet and orients the iron atoms as desired.
Well, it appears to be affecting a piece of pre-existing metal, I do not believe it is actually depositing any material. It could be a special alloy, I'm not sure if they mention that in the video. Somewhere you can actually buy the latch demo they show, it's around 20 bucks, I may pick one up. I wonder if it has any applications for reprap?Jimustanguitar wrote:Could it be a resin printer with suspended magnetic particles in it, and then they just use a coil to align the particles in a particular direction for each exposure? They could do multiple "mini exposures" per layer and come up with some really wild patterns that way.
$12 direct from them http://catalog.polymagnet.com/spring-latch-demo.htmlTheRealRocketBurns wrote:Well, it appears to be affecting a piece of pre-existing metal, I do not believe it is actually depositing any material. It could be a special alloy, I'm not sure if they mention that in the video. Somewhere you can actually buy the latch demo they show, it's around 20 bucks, I may pick one up. I wonder if it has any applications for reprap?Jimustanguitar wrote:Could it be a resin printer with suspended magnetic particles in it, and then they just use a coil to align the particles in a particular direction for each exposure? They could do multiple "mini exposures" per layer and come up with some really wild patterns that way.
Thanks for the link! I emailed them to ask about that, waiting for a response.Windshadow wrote:$12 direct from them http://catalog.polymagnet.com/spring-latch-demo.htmlTheRealRocketBurns wrote:Well, it appears to be affecting a piece of pre-existing metal, I do not believe it is actually depositing any material. It could be a special alloy, I'm not sure if they mention that in the video. Somewhere you can actually buy the latch demo they show, it's around 20 bucks, I may pick one up. I wonder if it has any applications for reprap?Jimustanguitar wrote:Could it be a resin printer with suspended magnetic particles in it, and then they just use a coil to align the particles in a particular direction for each exposure? They could do multiple "mini exposures" per layer and come up with some really wild patterns that way.
a bit over $15 with US Mail shipping But though it says in stock it rejects an attempt to order one or two so they may have an unstated minimum order quantity.
