V092 on Rambo board jelp needed
Posted: Wed May 04, 2016 10:10 am
by duvdev
Hi all
I want to install the v092 and I tried to use the Repetier-Firmware configuration tool for version 0.92.9 version
I want to do that in order to use the case_lights option to controll my heatlamp with SSR.
after installing V092 on the printer the UI if alot diffrent. I can see the temp of the bed and the extruder but when I want to turn on the the extruder on - nothing happends.
Also when I try to home the only moving exale it the Y and when tuch the end switch it doesn't stop an continue to move.
Please help - how to configure the V092 correctly? Or can any one tell me what code do I need to add to the V091 in order to contron a pin with on\off
thanks
