Embedded Raspberry Pi for Rostock Max V2
Posted: Fri May 06, 2016 2:20 am
So I have been using OctoPrint successfully and wanted to find a way to cleanly mount the Raspberry Pi within the print. So I came up with these goals and I think I found a solution that works pretty well:
[img]https://farm8.staticflickr.com/7182/26240876413_3fa82050a2_b.jpg[/img]
[img]https://farm8.staticflickr.com/7134/26845456325_bee0f50388_b.jpg[/img]
[img]https://farm8.staticflickr.com/7109/26240868553_3aa150de77_b.jpg[/img]
[img]https://farm8.staticflickr.com/7282/26845458675_1956cbb551_b.jpg[/img]
Check out my write up on Thingiverse
- The Pi needed to be inside the printer for portability and cleanliness
- The power and at least one USB connection as well as the main body needed to be accessible inside the printer. I wanted to have one and only one power plug on the printer and at least one USB to drive the printer board. Also I wanted the body inside so if I chose to upgrade to the Pi camera down the road, I can find a way to mount it in my enclosure with the cable running from the base up.
- I needed to have at least one USB and the Ethernet port exposed externally. My printer is in my basement at the limits of my home wireless, but I have a network jack I can plug into so I have good control and frame rates for the OctoPi cam.
