G29 using FSR's
Posted: Sun May 22, 2016 4:37 pm
I have been using OpenDact in a FSR setup to calibrate my machine, and that seems all to work now. I would not think this, but even after that challenge I have some leftover noob-questions...
What is the procedure to set the Z height automatically?
My research shows me I will probably have to give the g29 s2 command. But the problem is that it does not probe the points I specified in the repetier Z-probing chapter of my coniguration.h
Seems no matter what I set there it always probes at the same coordinates and it gets off-bed at the third probe, bumping into the z-tower. Also there must be some correction to upper z=0 after the average height has been determined. It does a too good job because after calibrating with opendact the distance from nozzle to bed is too high and the layer doen't stick.
Maybe someone with a working FSR setup can publish these settings? Thanks!
// #################### Z-Probing #####################
#define Z_PROBE_Z_OFFSET 0
#define Z_PROBE_Z_OFFSET_MODE 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 10
#define Z_PROBE_PIN ORIG_Z_MIN_PIN
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 0
#define Z_PROBE_SPEED 3
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 1
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 0
#define Z_PROBE_START_SCRIPT ""
#define Z_PROBE_FINISHED_SCRIPT ""
#define Z_PROBE_REQUIRES_HEATING 0
#define Z_PROBE_MIN_TEMPERATURE 150
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -77.94
#define Z_PROBE_Y1 -45
#define Z_PROBE_X2 77.94
#define Z_PROBE_Y2 -45
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 90
#define BED_LEVELING_METHOD 0
#define BED_CORRECTION_METHOD 0
#define BED_LEVELING_GRID_SIZE 5
#define BED_LEVELING_REPETITIONS 5
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define BENDING_CORRECTION_A 0
#define BENDING_CORRECTION_B 0
#define BENDING_CORRECTION_C 0
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0Maybe someone with a working FSR setup can publish these settings? Thanks!
