Derivative of Rostock -- Advice?
Posted: Tue Jun 28, 2016 6:01 pm
Hi, folks,
Have been lurking around the active 3D printer community in the SF Bay Area for several years. Not enough priority (or enough time
to jump in. Week or so ago, my grandson visited from southern California and we spent several days 3D printing on a friends Makerbot Replicator 2 and Mini. Now he's got the bug and I do, too
He's a budding scientist/engineer, so buying a printer (or even just building a kit) won't do, so in the Steve Jobs fashion "The journey is its own reward.", we want to design, analyze, and build a printer (definitely one faster than the Makerbots!) from scratch.
For more on my background, see my intro-to-the-forum posting: http://forum.seemecnc.com/viewtopic.php?f=2&t=10466
We've decided to start with the Rostock Max V2 (or later) as a starting point. I have a bunch of parts and materials already (e.g., my own stepper driver, some surplus high-quality linear rails from SLAC surplus, etc.) and the skills to design and analyze the components and evolving design, so expect to make a derivative. Expect to report on progress here.
But now, would love to draw on the accumulated wisdom of this group concerning our starting point and how we might proceed. Here are a bunch of specific questions:
Sorry. Hope they and the forthcoming replies serve to crystalize thinking in the group.
TIA,
Mike
- Starting point: I've downloaded all the available info on the Rostock Max V2 (Thanks, SeeMeCNC, etc.). For example, grabbed the Solidworks CAD file and imported them to Autodesk's Fusion360 system (cloud-based, built for group collaboration, free for non-profit use, check it out). Is this the latest published starting point (especially for the CAD files), or is there something later I should be using?
- Mechanical -- Case: No problem here. Expect to use the high-quality rails (aluminum "T" extrusion, plus hardened steel 1/2" dia. rod) for the uprights.
- Mechanical -- Platform: Heated? (Expect to do mainly PLA, but allow for other materials.) Material? (e.g., commercial stuff I saw at the Bay Area Maker Faire last month?)
- Moving parts -- Skates: Expect to design to fit our rails, but what size roller bearings? Have ordered some smaller ones from Banggood ("China, Inc.") to experiment with. Goal: reduce moving mass. Re noise: do I need to coat bearings or put them in a plastic/rubber roller?
- Moving parts -- Rods and balljoints: Expect to use carbon fiber tubing and metal balljoints (ordered samples from Banggood). Specific advice?
- Moving parts -- Belts and pulleys: Same as current Rostock?
- Moving parts -- Flying platform: Designed to fit selected hot-end, but would like to make it adaptable to other attachments (e.g., use the printer as a pick-and-place system with vacuum pickup head for PCB assembly).
- Moving parts -- Steppers: Same as current Rostock, or larger to allow faster acceleration and movement?
- Moving parts -- Extruder: Would like to use case-mounted extruder and Bowden tube to minimize moving mass. But this may make fiber control too difficult. A floating extruder hanging above the hot-end with a short Bowden tube may be a good alternative. Comments? Given all that, what's the "best" extruder design to use (given that I can machine extruder shafts with sharp 60º grooves and peaks on my mill)?
- Thermal -- Platform: Heated? How? Material?
- Thermal -- Hot-end: Probably the biggest unknown. What's the current advice on this? Should I machine my own from specialized materials (high-temp plastics, SS, etc.) or order it complete from "China, Inc."? Or start with the latter and evolve?
- Electronics -- Power supply: No problem. Will build into base.
- Electronics -- Controller board: The RAMBo board looks like a nice solution, but not for me. Too expensive and not modular. Looks like the best solution is to break down the board into more cost-efficient and flexible pieces:
- Stock Arduino Mega2560 or compatible (less than $10 from Banggood), and can be upgraded at any time.
- Either one board or a board with daughter cards for stepper drivers (already have) and heater drivers.
- Misc. cables and connectors.
- Electronics -- LCD: Compatible with Arduino and firmware (below)?
- Electronics -- SD reader: Compatible with Arduino and firmware (below)?
- Firmware: Is Marlin the best firmware to use for this kind of printer? (Already have downloaded the Arduino IDE, Marlin repo, and MarlinDev repo.) If so, I can take my firmware issues to the Marlin group....
TIA,
Mike
