Hi all.
so after i closed all my 7 printers I can print abs for 40+ hours without a problem with heat lamps.
the problem is that the Zero Lash Straps snap after a short period of time. any good solution to it?
is the SEEMECNC BALL-CUP DELTA ARM KIT with the new style injection molded carriages is better the tricklaser mod?
thanks
Zero Lash Straps from tricklaser problem
Re: Zero Lash Straps from tricklaser problem
I think Tricklaser is now selling springs instead of bands, You can probably ask Brian to send you some of the new tensioners for less than the arms.
ccavanaugh
216 / 217 size o-ring will work also. I use an ultra-flow durometer silicone material. The buna's and viton's would be too stiff.
