Printer Geometry Numbers? New vs. Old Carriages and Repetier 0.91 vs 0.92
Posted: Tue Aug 02, 2016 4:51 am
I'm trying to get the Dinosaurs set up to test the new effector platform plates by http://713maker.com/ and want to upgrade and recalibrate the printer first, so the new parts get a fair trial run without unrelated issues reducing print quality.
Backstory: After a lot of printing, I'm starting to see print quality issues that might be due to backlash. (Asymmetrical print artifacts appearing when the print path changes direction.) For a while, the carriage bearings have been occasionally squealing and clicking, and re-tightening the belts and carriage wheels reduced but didn't eliminate the problem. Rather than fiddle with that any more, I'm installing the new injection molded carriages.
I think the only firmware change for the new bearings should be the horizontal radius. Can anyone here review my summary of the change needed and help me verify the numbers as I've diagrammed them below?
I searched for the geometry change and found an official Carriage Horizontal Offset posted by jjjohnson here. I wasn't able to find a really comprehensive writeup so I'm posting the diagram below, just to be extra sure I understand the change 100% correctly.
There are two changes I need to consider:
- Changing from the old CheapSkates to the new Injection Molded Carriages
- Using Repetier 0.92, configured using their online tool, instead of Repetier 0.91 as provided by SeeMeCNC.
I stole the diagram from the Repetier configuration page and relabeled it with as the dimensions appear in the Repetier 0.91 firmware distributed by SeeMeCNC:
[img]http://gchristopher.net/3dprinting/rost ... iagram.jpg[/img]
In the 0.91 firmware for the old cheapskates, the values were:
End Effector Horizontal Offset: 33.0
Carriage Horizontal Offset: 38.4
Printer Radius: 198.25
Delta Radius = [Printer Radius] - [End Effector Horizontal Offset] - [Carriage Horizontal Offset] = 126.85
So for 0.91 firmware, the only change per jjjohnson should be that the End Effector Horizontal Offset is now 27.97. That means the calculated Delta Radius will change to 137.28.
That seems straightforward. Where I've gotten confused somewhere is on the Repetier 0.92 firmware.
Repetier 0.92 solicits the radius a little bit differently:
[img]http://gchristopher.net/3dprinting/repe ... iagram.jpg[/img]
Instead of calculating it, Repetier 0.92 just asks you for the Delta Radius, calling it Horizontal Radius ("ROD_RADIUS" is the constant).
Where I'm confused is that I downloaded someone else's sample firmware to get started with 0.92, and the value is currently set at 130, instead of 126.85. Presumably I'll want to increase the Horizontal Radius to accommodate changing from the CheapSkates to the Injection Molded carriages, but am I even starting with the right value in that constant?
Did I miss something in my interpretation of 0.91 and 0.92 geometry measurements? Have I been using the wrong number there since switching to 0.92?
Thanks in advance to anyone that can help me determine the correct values!
