accelerometer i2c error and no temperature
Posted: Thu Aug 11, 2016 10:20 am
Hi all,
I have recently finished building a Rostock Max V2 however have run into a problem. The build was fine and I successfully uploaded the Repetier firmware and the LCD screen is functioning as indicated in the manual (displaying sensible nozzle and bed temperatures, and default 100% speed and flow). I then installed mattercontrol and successfully connected to the printer however, at this point things went a bit awry.
Firstly, I noticed the temperature display in the software was showing 0C for the nozzle and the bed and just stayed there, despite the LCD screen displaying approx 20C.
I moved onto the basic functional checks and when I opened the terminal I found that there was an accelerometer i2c send/receive error and an SD card initialisation error (shown below).
-start
->Communication State: Connected
->M115
<-Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
<-Free RAM:879
<-Autoretract:0
<-X:0.00 Y:0.00 Z:0.000 E:0.0000
<-SpeedMultiply:100
<-SD init fail
<-iis2dh accelerometer initializing...
<-accelerometer send i2c error.
<-accelerometer i2c recv error.
etc...
This prevented me from proceeding with the functionality checks but I thought I'd check to see if I could manually move the axes and I found that I could (although there was a approx a 5 second delay after I clicked the move axis button in the software and sometimes I had to double click and sometimes it just didn't move at all).
I then tried to command a nozzle and bed temperature but this didn't work and the temp just stayed where it was and showed 0 in the software (also the heated bed LED did not come on).
After this I decided to recheck all the wiring - everything was correct and I was getting 12.2V at the powersupply connector (I only checked voltage in). Then it got weird, without changing anything I still had the accelerometer error like before but all of a sudden the temperature was showing up in the software and I was able to manipulate the temp of the bed and the nozzle. However this was short lived and after only for a few minutes it fell to 0 again. Also at one point the LCD screen showed rows of black squares for a couple of seconds then returned to the normal screen.
Does anyone have any thoughts on what could be the issue here? Am I right in thinking that if there is an i2c send/receive error this could be something physically wrong with the accelerometer or processor (as this protocol is only used between peripheral ICs and processors right?) or could it be configuration related? I'm new to this game so I'd really appreciate any advice
Also, not sure if it's relevant but I'm running Windows 10, repetier 0.92.2 and matter control 1.5
-start
->M115
<-Free RAM:879
<-Autoretract:0
<-SpeedMultiply:100
<-SD init fail
etc...
