No temperature detected
Posted: Sun Aug 14, 2016 5:06 am
Just finished the build of my Rostock Max but after connecting to my printer I am not getting any temperature feedback inside matter control.
The LCD screen is displaying the correct temp (approx 20C) but the temperature display inside matter control shows 0C for both the nozzle and the bed. I am unable to control the temperature either, if a temp is commanded it just stays at 0 degrees in matter control and the temp on the LCD screen is unchanged.
As the LCD is functioning fine, this appeared to be a connection issue between my PC and the printer but I can move the axes... (also I have checked Baud rate and it is set to 25000 which I am told is correct).
The strangest thing is that when I was rechecking all the wiring and had the Rambo board out of the base and was poking around, all of a sudden the temperature was showing up and I could control it. However, after a few minutes it just went back to 0 and has stayed there ever since.
Hardware/wiring issue? Or connection issue? I think my wiring into the power supply plug is a bit sketchy but I was measuring a full 12.2V going in.
Any help would be awesome
