Is this print ok?
Posted: Sat Aug 20, 2016 6:47 pm
by joe
Should I expect to get better than this? Excuse the upside down pics. They are right side up when you click on it.
Gray PLA
.14layer height.
Re: Is this print ok?
Posted: Sat Aug 20, 2016 7:52 pm
by Qdeathstar
it is a nice print, but yes. you can do better. I think you are underextruding just a little bit... or you are printing just a bit fast, as you can see gaps in the outer shells.
Posted: Mon Aug 22, 2016 9:20 am
by joe
Qdeathstar wrote:it is a nice print, but yes. you can do better. I think you are underextruding just a little bit... or you are printing just a bit fast, as you can see gaps in the outer shells.
Thanks, there is no gap to see in person but the camera picks up stuff like that. I used gray to show any flaws.
Posted: Mon Aug 22, 2016 10:48 am
by DeltaCon
I am pretty sure there are gaps between the perimeters. Maybe a picture taken more from above would convince me otherwise ;-)
Bit the vertical surface looks really smooth so that's great. Is it a small brim I see on the bottom? If not intended as a brim your first layer height should probably be raised.
