ORDER PLACED!!!! - Rostock MAX v3
cloneit3d
Post by cloneit3d »
I realize this post serves no purpose - just extremely excited to have placed my pre-order!!!!!!
:D :D :D :D :D :D :D :D :D :D
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
Re: ORDER PLACED!!!! - Rostock MAX v3
...and if you're really lucky, I'll have the docs done by the time they start shipping. :D
geneb wrote:...and if you're really lucky, I'll have the docs done by the time they start shipping. :D
"Fat Chance" :)
Well there's always the "JJ changed something" factor. :)
I DID pull off a neat trick (well for me anyway) - the docs will now feature a 1:1 scaled & dimensioned hardware chart so there will be no doubt as to what size & type of fastener is required for a step. You can print the page out and actually measure the drawing on paper and it'll match what your ruler says. :)
That's cool and useful!
Eric
Post by Eric »
It's way more fun putting things together without a manual anyway.
Post by Xenocrates »
Eric, True fun can also come from assembling them with the wrong manual, with a poorly translated one, or making someone else do it with those same constraints. One of my eternal favorites is a chinese laser cutter. Want to guess what 'Install Soft Dog' means in the context of getting it working?
Noircogi
Post by Noircogi »
I'm on the list also. Looking forward to joining the delta family. I was refreshing the we site waiting for orders go to live. :) SeeMeCNC was good enough to retro-actively apply John's discount code after he posted it.
cloneit3d
Post by cloneit3d »
Hmmmm discount code? Do tell-
I was under the impression the underside of the melamine is porous and was thinking about applying spar varnish. Would someone please comment on that?
The only thing I am lot looking forward to is Arduino- I have been spoiled running Smothieware.
Gene- love the idea of the scale hardware document!
Cheers!!
Qdeathstar
Post by Qdeathstar »
well, the melamine is sealed except for the edges, which can be easily painted... I only touched a spray-can 2-3 times prior to the Rostockv2 and was able to get a good looking job...
The electronics are fairly easy to upgrade.... I wish they would have upgraded to 32bit electronics, have been able to keep the price at 999 despite adding quite a few features so that's commendable... when I first saw $1899 for the v3 I thought that was crazy... then I realized it was fully assembled and with the pi.
Post by Mac The Knife »
cloneit3d wrote:Hmmmm discount code? Do tell-
Cheers!!
If they are using the same material as the V2, both sides are covered with melamine. Just the edges are exposed, and they soak up paint like a sponge.
I've used Killz Primer in the past to seal the edges. Other folks have used 1/4" wide, colored pinstriping tape. YMMV. :)
Here's the hardware chart:
full size screw drawings.PDF
(183.38 KiB) Downloaded 418 times
cloneit3d
Post by cloneit3d »
Thanks for the tips on the melamine guys!!!! I will apply the colorless spar varnish on a test piece and see if there are any ill effects.
Cheers!!!!
Return to “RostockMAX v3”
