Pillowing vs over extrusion
Posted: Thu Sep 29, 2016 7:28 pm
by Qdeathstar
Hi,
I have this print I am trying to print and I am having some issues with the top layer.
I'm sure part of my issue is pillowing.. But I increased the top layers to 10, and the top surface is still pretty rough.
Do you think this is due to pillowing or over extrusion? My other prints that don't have huge flat tops seem ok....
I'm not running any cooling currently, but that will change soon.
Re: Pillowing vs over extrusion
Posted: Thu Sep 29, 2016 9:14 pm
by lightninjay
Your last line of "not running any cooling" should be your magic bullet.
Cooling is essential to let the plastic bridge properly on top layers. Once you have proper cooling, try it once more with between 3 and 5 top layers.
Posted: Thu Sep 29, 2016 9:33 pm
by Qdeathstar
should have said before.... this is abs, so, cooling stil a factor?
Posted: Thu Sep 29, 2016 9:47 pm
by lightninjay
In some cases, cooling with abs can be a good thing. If you want to try, you can lower your printing temps a bit.
Posted: Thu Sep 29, 2016 11:41 pm
by Tincho85
Agree, I do use cooling fans for ABS. Mostly at 20% fan speed, for bridges, overhangs and last layers like yours with a lot of detail.
For structural parts is not recommended as you can have some delamination.
Also, polish the tip of your nozzle a bit.
Posted: Fri Sep 30, 2016 8:02 am
TIL Stormtroopers can't hit print settings either. *grins, ducks, & runs* :D :D :D
Posted: Fri Sep 30, 2016 10:02 am
by Jimustanguitar
You wearing your red shirt today, Gene?
Stormtroopers can probably hit that, still.
Posted: Fri Sep 30, 2016 10:26 am
by joe
Tincho85 wrote: Also, polish the tip of your nozzle a bit.
I polish the tip of my nozzle as often as possible.
Posted: Fri Sep 30, 2016 10:29 am
Nah. They'll miss, but I'll still die. :D
Posted: Fri Sep 30, 2016 11:45 am
by lightninjay
Polishing the tip of your nozzle can help to prevent build-up, and promotes a happier printing mind-set. ;)
Posted: Fri Sep 30, 2016 12:36 pm
by joe
I could not agree more. :D
Posted: Fri Sep 30, 2016 1:20 pm
by Tincho85
It took me some time but finally got it :o :D
