Cura Version?
morgandc
Cura Version?
Post by morgandc »
What is the latest version of Cura that works with the Rostock Max v3? (windows version)
Re: Cura Version?
All versions of Cura will "work with the V3". Are you actually asking for a V3 printer and slicing profile? If so, then Cura does not have out of the box support for V3 but I posted a reasonable profile in another thread here earlier this week.
morgandc
Re: Cura Version?
Post by morgandc »
Based on that, perhaps I should ask how to use the profile on a clean install of Cura. There are no printers that appear to be delta based to select initially. There is a subfolder full of *.json files that appear to be printers, but format doesn't match the profile you posted.
Re: Cura Version?
Like I said in my post, I do not use Cura actively. My understanding is you use the Import command to import the "ini" file. I tried it once.
morgandc
Re: Cura Version?
Post by morgandc »
Thanks, I will dig around a bit more and see if I find anything. I have a particular part I want to print, and was going to see if any particular slicer did better with.
Return to “RostockMAX v3”
