3/4 way through print satin takes control
Posted: Tue Oct 18, 2016 7:44 pm
by Twac1
So it's happened twice, about 50-75% done and once while I was away and onother print 5 later, the hot end jumps off the print and dive bombs into the bed a few times, then it floats an inch or so of the bed and tops the rest with pla hair?!?!
Running by sd
Mc slicer
V3
Copied the g code to notepad and scrolled through but nothing popped out, didn't read every line
Re: 3/4 way through print satin takes control
Posted: Tue Oct 18, 2016 7:54 pm
Satin or gloss?
Posted: Tue Oct 18, 2016 7:57 pm
Your problem is not a slicer problem. Something is going on to cause an axis (or 2 or 3) to miss steps. Were you watching when this happened? What did you see if so?
Slipping belts, slipping pulleys on the stepper, problems with the connectors to RAMBo and other things could cause this.
Posted: Wed Oct 19, 2016 7:19 am
by Mac The Knife
Printing at the extreme edges of the bed, to fast will cause that also.
Posted: Sat Oct 22, 2016 12:42 pm
by Qdeathstar
I had the same issue after my last upgrade, I had moved where the Bowden was and didn't properly strap it up.... It was getting stuck under the x-axis carriage causing it to miss steps.
I have to tell you there is nothing more disturbing that seeing a delta going wonky after missing steps...
