DEF temps random and blinking heat bed LED
Posted: Wed Nov 16, 2016 4:00 pm
Hello everyone,
Been printing for a few weeks with the new, badass V3 and keep running into DEF temps at random times. I have replaced the ENTIRE hot end and that seemed to work for the first 20 minutes until it went DEF again. I then went and replaced the heat bed thermistor AGAIN and it is printing fine for the moment
), but the heat bed LED is very dim now and blinking in a non-random pattern, it's in sync with the motor it seems. Any ideas? I've checked my wires at least a dozen times as well as the connections and they all check out. Also, keep in mind that I am using a brand new, factory built, hot end that was delivered today. I am behind on several orders and could really use some guidance.
Thank-you in advance for your time and thoughts!
Brandon Williams
Brandon Williams
