Holes in top layers
Posted: Mon Jan 09, 2017 1:58 pm
by deadpool66
Hi everyone!
Been dialing in my Rostock Max 2 since I replaced the hotend and am very close to acceptable for prints.
I have adjusted extrusion and added more top layers but still getting holes in the top. Any ideas?
[img]http://i11.photobucket.com/albums/a182/deadpool2099/20170109_090826_zpsggxlpbw7.jpg[/img]
Re: Holes in top layers
Posted: Mon Jan 09, 2017 2:06 pm
This is very typical with domed top surfaces. If you think about what's going on and do a few drawings you'll see that there are three options:
1) use more perimeters - it looks like ou are using 1 in the photo, increase that to 2 or 3
2) make the extrusion width a lot wider, which is usually not practical
3) make the layers thinner - which really increases the print time
I'm not sure what you mean by "added more top layers".
Posted: Mon Jan 09, 2017 2:22 pm
by deadpool66
In simplify 3d trouble shooting it says adding extra solid top layers may fix the issue. I try adding some more perimeters.
Posted: Tue Jan 10, 2017 9:23 am
If you're using S3D, figure out what layer begins the top and back off 20 or so and print at a much lower layer height.
Posted: Wed Jan 11, 2017 7:36 pm
by Ravitch
Also, to top off what geneb said above increase your infill below the top layers. My top layers always come out perfect if I numb up the infill in the 10 layers below the top solid layers.
Posted: Fri Jan 13, 2017 12:15 am
by 626Pilot
In KISSlicer, I would increase the "skin thickness."
