Cracking noises from stepper motors
Posted: Sun Feb 19, 2017 5:37 pm
Hello,
I bought an Rostock Max V3 three weeks ago, actually imported it to Germany, heard so many good things about it.
However, I am having quite a lot of problems with it right from the start.
At first, it printed without any big noise-issues, however the quality was bad and the outer shell and the filling was not connected.
I adjusted the belt-tension and checked everything twice, but nothing helped. Instead, some grinding and cracking noises from
the steppers started to occur randomly. It sounds like it comes from bad bearings or so, but I wanted to know what you think:
https://youtu.be/K67pwwmh8RQ
Again, doesn't matter which step it performs, but it seems like it's worse when the speed setting is really high or it's at the edge of the printing area.
I am really thankful for any help and appreciate every answer!
P.S.: Recently, I upgraded to a Duet Wifi Board, too. That worked well!
