Effector Tilt
Posted: Wed Mar 08, 2017 7:32 pm
Hi,
I am having an issue with effector tilt which is affecting my printers print quality. Assuming I have a valid method for testing, it seems like the dumb-bells on the seemecnc trucks are not level with the bed.
Here is the X axis. The first picture shows the bed, and the level is oriented the same way as the trucks are. The bed is level, but the dumb-bells lean a little bit (i also removed the arms and tested (not pictured) but the result is the same).
X axis at bed:
[img]https://s28.postimg.org/llcirj1ul/IMG_4746.jpg[/img]
X axis at dumbells:
[img]https://s28.postimg.org/7t2p9n0gt/IMG_4747.jpg[/img]
I also placed a level on the tower to see if the tower was leaning
[img]https://s28.postimg.org/67nfhtq8t/IMG_4752.jpg[/img]
Here is the Y axis:
[img]https://s28.postimg.org/tgrnk30v1/IMG_4748.jpg[/img]
[img]https://s28.postimg.org/6tcedxlb1/IMG_4749.jpg[/img]
Here is the Z axis:
[img]https://s28.postimg.org/oko0se0pp/IMG_4750.jpg[/img]
[img]https://s28.postimg.org/bujsfasrh/IMG_4751.jpg[/img]
Sadly, there doesn't seem to be a way to adjust this. Any thoughts? Anyone experienced something similar? Thanks!
Because the dumb-bells are not level, the bearings (or balls) are not at the same height, and this is causing? effector tilt. I took some pictures to better explain.Duet WifiWiki wrote: The two bearings on each carriage must be at the same height
The bearings in each pair on the effector should be at the same height by design. The bearings on the carriage at the other end of the rods must also be at the same height, otherwise the effector will be forced to tilt when it is close to the tower with that carriage on it. Carriages are typically screwed to carriage trucks or linear rail sliders, and you can usually rotate a carriage slightly about the axis passing through its face to get the bearings at the same height before you tighten the screws.
X axis at bed:
X axis at dumbells:
Here is the Y axis:
Here is the Z axis:
