Hot end goes to the bottom and stops.
Posted: Thu Mar 23, 2017 11:44 pm
by dmo
I'm not sure if this is a HE280 issue or MC. Everything moves and calorbrates perfectly. I even used the calorbration wizard gcode. When I go to print the calorbration cube the HE goes to the bottom at the X tower, moves a bit and stops. After a while a red light starts flashing on the HE. I'm actually using a V2 but posted here because of the HE280.
Re: Hot end goes to the bottom and stops.
Posted: Fri Mar 24, 2017 1:23 pm
by dmo
Problem fixed. Turns out it's a Matter Control issue. I imported a gcode from a different slicer and it works perfect. It's been a while since I've used Matter Control and the RAMBO board so I probably just have a setting off.
