CURA OBJECT GCODE - LOOKS WRONG WHEN OPENED IN MATTERCONTROL TO PRINT
Posted: Thu Mar 01, 2018 8:36 am
by magicmarc
HI, I'M TRYING TO DO THE SIMPLE BENCHY PRINT ON THE H2 DELTA.
I OPENED THE FILE IN CURA 3.2.1, USING THE SLICING PROFILES FOR THE HE280 DEFAULT AND THE 140X140X295, 0.5 1,75 PRINTER SETTINGS, THEN ALL LOOKS GOOD, I EXPORT THE BENCHY GCODE FILE.
WHEN I OPEN IT IN MATTERCONTROL TO PRINT IT LOOKS FLAT, SQUESHED.. IVE ATTACHED THE PICTURES.
THANKS FOR THE HELP
Re: CURA OBJECT GCODE - LOOKS WRONG WHEN OPENED IN MATTERCONTROL TO PRINT
Posted: Thu Mar 01, 2018 8:47 am
Like I mentioned in my reply to your other thread, Cura's not the problem here. :)
Posted: Thu Mar 01, 2018 9:17 am
by magicmarc
gene this one isnt a print top swilling error, like the spinning top that was too hot and/or too fast/ or too little layer time...
this was merely opening a .stl in cura, with the slicing profiles for the H2, then saving as gcode, then importing the gode to matercontrol, no print, as soon as it was added/opened into mattercontrol it just 'looked incorrect, no top half... i did the same with another .stl file and it too was cut off, no top, smuched down... as i said i didnt print this, its just opened wrong in mattercontrol...
Posted: Thu Mar 01, 2018 10:51 am
Like I said, the problem isn't with Cura. If you have to print via USB, grab Repetier Host and use that. (or Pronterface for that matter)
Posted: Fri Mar 02, 2018 7:25 am
by magicmarc
thanks gene, im not familiar with octoprint, repetier host, or pronterface, but i will look them up this weekend and learn a bit... and try.. today im going to try just the sd card direct print, no mattercontrol (cura>>file>>sd card>>H@ insert & print)
as always, i learn something new and important everytime you reply!
Posted: Fri Mar 02, 2018 7:49 am
You're quite welcome. Hopefully you're not learning new epithets or insults from me. :) (yet) *laughs*
