Max v2 HE280 upgraded - bed leveling gcode?
lmorgan3d
Post by lmorgan3d »
Somehow, I lost my gcode file that was used to level/calibrate the print bed. It has been a while and I am not certain of which file I used before, it probed the leveling points and update the machine by just loading the gcode file and running it.
Rostock Max V2 with HE280 upgrate with 92.2 firmware.
Thanks for the hellp ..Lynn..
Re: Max v2 HE280 upgraded - bed leveling gcode?
With the HE280, you only need to do a G29 for a basic leveling, and then you can go here: https://www.seemecnc.com/pages/delta-calibration-wizard to finish the process.
If you're using OctoPrint, you can use my plugin to do that automatically. You can get that here: https://github.com/geneb/OctoPrint-Delta-Calibration - it's based on the same code that dc42 wrote for his browser-based calibration tool.
lmorgan3d
Post by lmorgan3d »
Thanks for the help!
I did find this in the V3 thread which appears to have a little more to it. Is it better, will it work with V2 upgraded for leveling?
; Rostock Max v2/v3 Delta Auotcalibration Script
G69 S2 ;Endstop Calibration
M117 ENDSTOPS CALIBRATED
G68 ;Horizontal Radius Calibration
M117 HORIZONTAL RADIUS CALIBRATED
G30 S2 ;Z height calibration
M117 Z Height Calibrated
M500 ;Save values to EEPROM
G4 S2
M117 SAVING CALIBRATION
..Lynn..
If you have an HE280 equipped v2, the only thing you need to do is run the calibration from the front panel. I've never used any kind of script like the one you show.
lmorgan3d
Post by lmorgan3d »
The Rostock Max v1/v2 HE280 Hotend Upgrade instructions (at the end) point to a video: "Calibration your new/old Printer".
In the video, it runs v3probing.gcode, which is narrated identifying platform tilt by 3 points, horizontal radius, max z height sections of the code.
Your first response talked about doing a G29 basic leveling (which I thinks is above), and then running the wizard for a 10 point bed calibration.
Do I have this correct? ..Lynn..
Ah, ok. The v3probing.gcode is incorporated into the firmware now. You just need to run the "Full Calibration" off the Advanced menu. After that finishes you can do the 10 point calibration if you need to.
lmorgan3d
Post by lmorgan3d »
Many thanks for the help!!
..Lynn..
You're welcome!
