BossDelta300 heater fail
Posted: Fri Jan 13, 2023 3:07 pm
by geofbuck
Does anyone know where the fuse is for the heater? I was told there was a 5A fuse on the duet control board but I opened up the base of the printer and I don't see one. There is only a blue automotive 15A fuse. Where else could it be located? My brand new unit won't even print. It fails when trying to heat before printing even starts.
Re: BossDelta300 heater fail
Posted: Sun Jan 15, 2023 11:47 am
The fuse locations can be found here:
https://docs.duet3d.com/Duet3D_hardware ... e_Overview
look at the "features" section - the fuses are shown with a red highlight and they're on the right side of the board.
I would also check to make sure that the connectors on the SE300 haven't come un-seated - even a little bit could cause an issue.
