new lcd adapter routing
bplemmons
Post by bplemmons »
Can someone tell me which ribbon cable goes to whichconnector on the new rambo adapter? Thanks. Bill
cambo3d
Re: new lcd adapter routing
Post by cambo3d »
If you look at the pin out from the lcd wiring instructions. You can determine which is which by reading the pins with a multimeter
but I've done this already. The "A connector" (left most wire on lcd panel) is the top header on the adapter board . "B connector" is the bottom header. I have photos in my build log.
I'm also waiting for an email from john at seemecnc just to verify. I'm correct.
bplemmons
Post by bplemmons »
Thank you so much, I talked Steve today and he even didn't know.....
