Fast and smooth operation?
Posted: Sat Mar 16, 2013 8:59 pm
by tom10122
Currently, my printer is quite jerky especially at higher speeds. Should I turn acceleration up or down?
Re: Fast and smooth operation?
Posted: Sat Mar 16, 2013 9:24 pm
by MorbidSlowBurn
What do you mean by jerky? Is it still moving the correct distances? What software are you using and what settings? Which firmware? What board version?
Posted: Sun Mar 17, 2013 4:58 am
by aehM_Key
If you meen the noise, than make sure, that you install a spacer like here http://forum.seemecnc.com/viewtopic.php ... 289&p=7094 or here http://www.3dfabricationworks.com/rosto ... rades.html .
After this you can tune the position of the free running gear, so it is in the middle of the two other ones.
If it skips steps, then increase the current. If have mine now set all the way up to 255.
Posted: Sun Mar 17, 2013 11:16 am
by tom10122
It still moves the correct distance, prints fine. It just bothers me that it jerks like it does.
Posted: Sun Mar 17, 2013 12:59 pm
by aehM_Key
MorbidSlowBurn wrote:What do you mean by jerky?
A bit of jerkyness (is this an English word? ;)) is normal, because of the stepper motor.
Posted: Sun Mar 17, 2013 1:15 pm
by cambo3d
also wasn't the jerkiness, also cause by firmware, switching to repetier was smoother from what others have said.
