Kisslicer and the skirt
Posted: Sun Mar 17, 2013 10:14 pm
by foshon
Is it possible to get a continuous skirt like in Slic3r? I use a 5mm skirt on long/large prints, but have to use Slic3r to get it. I really don't care for the raft, with no perimeters it seems to curl as quickly as the print I am trying to help. Slic3r seems to implement it as an "enlarging" of the first layer by 5mm which works out perfectly for me.
Re: Kisslicer and the skirt
Posted: Mon Mar 18, 2013 2:26 am
by aehM_Key
I think it's called "brim" and already in the Kisslicer wishlists: http://kisslicer.com/forum/index.php?topic=361.30 http://kisslicer.com/forum/index.php?topic=163.0
Posted: Thu Mar 21, 2013 8:21 am
by foshon
Thank you. Do you know if it is in the current beta? I have tried several times to register on their forum, I never get the activation email.
Posted: Thu Mar 21, 2013 8:52 am
by aehM_Key
I don't think so. Which version do you need?
Posted: Fri Mar 22, 2013 6:29 am
by foshon
I'd like to play with the new beta. I can't find his github.
Posted: Fri Mar 22, 2013 10:25 am
by aehM_Key
You wrote already, that you need the beta. But for which sysem? Mac, Windows, 32Bit, 64Bit, ... ?
Posted: Fri Mar 22, 2013 11:28 am
KISSlicer is not open source so no github. You can find the 1.1.0 release candidate (no longer beta) in the forum: http://kisslicer.com/forum/index.php?board=6.0
Posted: Fri Mar 22, 2013 7:50 pm
by foshon
Windoze xp
Without a login to the forum pictures and links don't work. This is the root of my issue.
Posted: Fri Mar 22, 2013 7:51 pm
by foshon
mhackney wrote:KISSlicer is not open source so no github. You can find the 1.1.0 release candidate (no longer beta) in the forum: http://kisslicer.com/forum/index.php?board=6.0
I actually am a "pro" user. LOL
Posted: Sat Mar 23, 2013 6:10 am
by aehM_Key
foshon wrote:I actually am a "pro" user. LOL
I don't know what this means or what you want to say.
Again: Do you need 32 or 64 Bit?
Posted: Sat Mar 23, 2013 6:49 am
by foshon
I'm sorry, missed that 32 bit. That was meant for Mr. Hackney.
Posted: Sat Mar 23, 2013 6:55 am
by aehM_Key
Here you go
Posted: Sat Mar 23, 2013 7:49 am
by foshon
aehM_Key wrote:Here you go
Thank you sir!
Posted: Tue Mar 26, 2013 5:42 pm
All of the RC2s are here: http://kisslicer.com/forum/index.php?topic=489.0
I am trying it out now. It has some new features too (italics):
EDIT 2013-03-25: updating to RC2
* Seam can now be randomized (Jitter) and the depth of the seam crossover can be modified.
* Fixed some tab-order issues
* Fixed some translation / menu / tooltip string update issues
* Added a delta speed limit (1st layer speed limit is increased by this each layer, so you can do gradual speed increases)
* Fixed a huge crowning bug! The speeds and widths should be sane now.
* G-code comments now wrap to stay within 62 characters
* removed some double quotes that were choking the translator
The seam randomizer is great! I missed that from Slic3r.
Posted: Thu May 09, 2013 7:07 pm
by ichiban
do you find that the seam randomizer give you inconsistent and jagged edges?
Posted: Tue Jun 04, 2013 11:02 am
by Bill Havins
ichiban wrote:do you find that the seam randomizer give you inconsistent and jagged edges?
Yes.
