z height off and no extruder heat
Posted: Tue Mar 19, 2013 2:50 am
by bplemmons
I'm trying to calibrate my rostock but I'm stumped on 2 issues. The print head zeroes out 2 inches above the plate. the instructions say to change the z home pos. by increments of 10 but i must not be on the right setting because nothing I have tried will bring in down anymore than 2' too high.
The other problem is the extruder won't heat up. I checked the wires for continuity and I am plugged in to extruder 0 on the rambo and the bed heat works so I don't think it's the mosfet fuse....
HELP!!!!! (please)
Re: z height off and no extruder heat
Posted: Tue Mar 19, 2013 4:20 am
by bplemmons
I realized that the z home pos is in the calibration h settings so I got that part covered now, is there something else in the firmware I need to do to get the extruder to heat up?
Posted: Tue Mar 19, 2013 12:21 pm
bplemmons wrote:I'm trying to calibrate my rostock but I'm stumped on 2 issues. The print head zeroes out 2 inches above the plate. the instructions say to change the z home pos. by increments of 10 but i must not be on the right setting because nothing I have tried will bring in down anymore than 2' too high.
HELP!!!!! (please)
Heated bed is connected to a completely separate 12V line and independently fused.
If the Light comes on when you turn on the hotend the fuse is fine if it doesn't check it with a meter.
Posted: Wed Mar 20, 2013 12:04 am
by bplemmons
Looks like it is the fuse, got one on order....
Thanks again for your time
Posted: Wed Mar 20, 2013 12:15 am
by cambo3d
bplemmons wrote:Looks like it is the fuse, got one on order....
if your fuse blew, you need to check for shorts also.
