Bearing Flashing
foshon
Bearing Flashing
Post by foshon »
I skipped cutting the flashing from these as it seemed like a waste of time. None of the bearings that have the covers have parts that contact that area. I didn't to risk cutting into to the face of the cover just for having it look cleaner. Am I wrong that nothing contacts here?
Purple = sarcasm
cambo3d
Re: Bearing Flashing
Post by cambo3d »
i didnt' worry about it either
MorbidSlowBurn
Post by MorbidSlowBurn »
I didn't "cut the flashing off. What I did was run my nail over the edge and it took the flashing right off. The only issue I could really see is that it could cause a problem when putting the cover on the bearing. If the flashing folded over and was trapped, it could cause a high spot on the cover. Otherwise the flashing appears to be in a non-contact area so won't affect performance.
foshon
Post by foshon »
Cool, thanks to you both!
Purple = sarcasm
