Ratty prints after firmware? RECHECK EXTRUSION STEPS
Posted: Sun Apr 28, 2013 11:03 pm
Hey Folks I spent 2 days trying to figure out why my prints were so ratty after the Firmware update
If you're getting this problem, ADJUST THE EXTRUSION RATE in the Eprom in Repetier!
I checked everything...and the thing that mattered I figured out last.
What a genius I am!
I adjusted steps in Arduino and assumed that would be enough, it always was before, but for some reason REPETIER overrides the Arduino setting.
It was still at 292! even after I changed it in Arduino a few times and uploaded, Repetier still used 292.
I did Heat changes, Checking Cheapskates, installing new 608 bearing caps on Chepaskates, Arms, PID Tuning, Checking Belts and Motor Cogs, using new and older Nozzle, oiling the joints on the arms and using or not using retraction...plus wasting alot of filament. :C
At least everything has been rechecked and parts replaced but it was pretty frustrating.
So don't assume Arduino will update, check the EPROM settings in Repetier and that all your settings are matching
Here's the difference so far so it worked
What a genius I am!
