Hot end issues
Posted: Fri May 31, 2013 10:11 pm
by ROBRMI
Ok, so all was well, with some minor print quality issues i was working on, and then i noticed a leak coming out of the hot end where the peek enters the metal of hot end. It was broken, so i ordered a new hot end, and some peek insulators so i could repair and have a spare hot end. The new hot end, as soon as i put it in, was heating slowly, but heating up. Finally got up to 225 deg c. I was noticing some smoke comingg out of the little holes on the hot end, but didn't worry. So i made a small extrusion feed manually, and the hot end dropped down sleightly, and i noticed the peek insulator was melted where it enters the hot end?
any suggestions? any recommendations for a good method to clean out both hot ends from the melted plastic to rebuild the head?
not sure why it melted. Thermister was showing 225 deg C.
Re: Hot end issues
Posted: Fri May 31, 2013 10:24 pm
ROBRMI wrote:Ok, so all was well, with some minor print quality issues i was working on, and then i noticed a leak coming out of the hot end where the peek enters the metal of hot end. It was broken, so i ordered a new hot end, and some peek insulators so i could repair and have a spare hot end. The new hot end, as soon as i put it in, was heating slowly, but heating up. Finally got up to 225 deg c. I was noticing some smoke comingg out of the little holes on the hot end, but didn't worry. So i made a small extrusion feed manually, and the hot end dropped down sleightly, and i noticed the peek insulator was melted where it enters the hot end?
You have to verify the thermistor temperature before trusting it. The only way to do that is with a thermocouple.
You're certainly not melting peek at 225 it QA probably over 250C.
The thermistor will read incorrectly of it's not well seated and it will read low if you have a fan blowing on the heater block.
Re: Hot end issues
Posted: Sat Jun 01, 2013 1:32 pm
by ROBRMI
Polygonhell wrote:ROBRMI wrote:Ok, so all was well, with some minor print quality issues i was working on, and then i noticed a leak coming out of the hot end where the peek enters the metal of hot end. It was broken, so i ordered a new hot end, and some peek insulators so i could repair and have a spare hot end. The new hot end, as soon as i put it in, was heating slowly, but heating up. Finally got up to 225 deg c. I was noticing some smoke comingg out of the little holes on the hot end, but didn't worry. So i made a small extrusion feed manually, and the hot end dropped down sleightly, and i noticed the peek insulator was melted where it enters the hot end?
Thanks for the info. I managed to rebuild with the spare peek i had purchased. The thermister broke a wire at the glass bead, so i've got additionals coming, old one broke too, so i'm testing with heated bed thermister installed on hot end. Guess i'll go get a thermocouple/heat sensor today to test. Is there a parameter setting in config to offset/scale the thermistor feedback?
