Extruder Test
Posted: Wed Jul 24, 2013 1:42 am
by jmick
Is their a written test for the extruder to insure its working. How do you turn on the extruder to test it. Is their a you tube video showing
how to check the extruder manually?
Re: Extruder Test
Posted: Wed Jul 24, 2013 10:31 am
by JohnStack
Are you having a specific problem that you can tell us about?
There are a number of posts about extruding. This is a decent and detailed one.
http://forum.seemecnc.com/viewtopic.php?f=54&t=1768
Also, Polygonhell's typical thorough instructions:
http://forum.seemecnc.com/viewtopic.php?f=54&t=1163
About retracting and sending filament through the extruder:
http://forum.seemecnc.com/viewtopic.php?t=1145&p=5254
These were found via google search.
Or, did you mean the hot end?
Re: Extruder Test
Posted: Wed Jul 24, 2013 11:44 am
Me, I wanna see the extruder take a written test. Was it given time to study before hand? :D
*runs*
Re: Extruder Test
Posted: Thu Jul 25, 2013 4:38 am
by kbob
jmick wrote:Is their a written test for the extruder to insure its working. How do you turn on the extruder to test it. Is their a you tube video showing
There are buttons in Repetier Host labeled Extrude and Retract. There are also commands in the firmware/LCD menus to extrude and retract. What do you want to test?
Re: Extruder Test
Posted: Thu Jul 25, 2013 10:30 am
by jmick
How do you turn the motor on for the first time and load the filament. I push the red lever and nothing happens? The motor does not activate when I push it and is not turning. Does this not work with power on, must you turn it on with the software to load your filament?
Re: Extruder Test
Posted: Thu Jul 25, 2013 11:09 am
by ApacheXMD
The red lever is just a spring loaded bearing that pushes the filament against the hobbed gear. It doesnt activate the motor. You have to get the motor turning in software or through the LCD controller in order to feed filament through the extruder motor.
Re: Extruder Test
Posted: Thu Jul 25, 2013 11:11 am
by jmick
Tks apache
