PTFE tubes
Posted: Sat Jul 27, 2013 4:29 pm
by jake
I warped, ruined and split my PTFE tubes and wanted to replace both of them. Ware can I get a replacement please.
Re: PTFE tubes
Posted: Sat Jul 27, 2013 4:52 pm
by kbob
Rostock MAX uses PTFE tubing in three places.
  • The Bowden tube is PTFE.
  • The thermistor leads are sleeved in PTFE.
  • The hot end resistor leads are sleeved in PTFE.
McMaster-Carr sells PTFE tubing in many sizes. For the thermistors, 5335K9 is the part number. For the resistors, it's 5335K13. I don't know the part number for the Bowden tube, but you want 2 mm ID.
SeeMeCNC also sells tubing for the Bowden tube.
http://shop.seemecnc.com/Teflon-Tubing- ... gs_c10.htm
Re: PTFE tubes
Posted: Sun Jul 28, 2013 10:07 am
by jesse
eBay has them too but not transparent
Re: PTFE tubes
Posted: Sun Jul 28, 2013 12:04 pm
by tom10122
It doesn't need to be transparent to work
Re: PTFE tubes
Posted: Sun Jul 28, 2013 2:34 pm
by jake
I did not realize that. I am talking about the tubes inside the hot end.
Re: PTFE tubes
Posted: Sun Jul 28, 2013 8:56 pm
You know that the outer PTFE tube in the hot end is split on purpose, right?
