Damn you shrinkage! (trivial I know)
Posted: Sun Jul 28, 2013 6:19 pm
by lordbinky
So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
Re: Damn you shrinkage! (trivial I know)
Posted: Sun Jul 28, 2013 7:11 pm
by kbob
lordbinky wrote:So on a hollow cube ( .2mm layers, abs) my first layer prints spot on, a 10 mm cube is 9.97, then you go up 20 layers and the plastic pulls in so the cube is ~9.82mm. Everything is lined up, no skewing, good adhesion on layers, good adhesion to the bed...the only thing is that it contracts as it moves away from the bed (it is consistant after that). Is there anything to change to counter that effect?
I think you need to set your infill to 60% or so. (-:
Posted: Sun Jul 28, 2013 7:37 pm
by astroboy907
No offense but your avatar is the perfect representation of this post... :P
Posted: Sun Jul 28, 2013 8:09 pm
by lordbinky
Hmmm.... Nope, don't see it. :shock:
by lordbinky
Psh, but then it wouldn't be a hollow cube.
