command sends z axis down
Posted: Mon Dec 16, 2013 9:25 pm
by tc3jg
hey i was messing around with the LCD on the printer and messed up some settings that jacked my printer up. the device only goes down 10cm when i try to home all on the computer.
Re: command sends z axis down
Posted: Tue Dec 17, 2013 1:17 pm
by Lochemage
Not much info to go on, but first I would check your EEPROM settings and make sure everything is still correct; I've had problems before when messing with them on the LCD screen caused some values to clear.
Posted: Tue Dec 17, 2013 11:43 pm
by tc3jg
Lochemage wrote:Not much info to go on, but first I would check your EEPROM settings and make sure everything is still correct; I've had problems before when messing with them on the LCD screen caused some values to clear.
Thanks Lochemage, Yeah i know its very small amount of data but to be honest everything i touched using the LCD i felt i moved back. I would even be ok with starting from scratch at this point
Posted: Sun Dec 22, 2013 9:56 am
by tc3jg
anyone know how to just start over and follow gene's set up instructions again for the Rambo?
Posted: Sun Dec 22, 2013 10:49 am
tc3jg wrote:anyone know how to just start over and follow gene's set up instructions again for the Rambo?
Download the latest manual.
Go to page 152 and start the software installation, and continue with every step, including all calibration steps.
Essentially page 152 to the end of the manual. It's going to be a pain in the whatever but with losing all of your
settings there aren't too many options.
