Z height crash
Posted: Fri Dec 20, 2013 3:10 pm
I am setting up the new LCD display and recalibrating the software, so In general I'm starting over with the software install. My machine is about 1 1/2 years old and did not come originally with the LCD. It seems to be fine and powers up and displays information.
I am at the point where the manual says to run G0 Z10 F3500 which should rapid traverse and stop the nozzle 10mm above the heated bed. I measured the nozzle height and it measures 354 (including the added 2mm) from the nozzle to the heated bed with the glass on it when the machine is at X0 Y0 Z0. When I run the code it crashes into the bed. So far I have trouble shot it to the point that I get a reading of 119mm when I manually jog it down and the nozzle is touching the bed. I have saved the 354 measurement in the EEPROM and I went into the Arduino software and saved it there as well. What setting is incorrect or what am I doing incorrectly?
Thanks, Matt
Thanks, Matt
