Strongest Filament?
Posted: Wed Mar 26, 2014 11:48 pm
by printer999
I am looking for a strong filament That can withstand quite a lot of of force and It also Must be pretty easy to print with like PLA. It would also be nice if it could be in color. I have been looking at the T-Glase and the Taulman 645 filament. What of these would best fit my needs? I am printing on the orion. If you have other suggestions just tell me.
Re: Strongest Filament?
Posted: Thu Mar 27, 2014 12:00 am
printer999 wrote:I am looking for a strong filament That can withstand quite a lot of of force and It also Must be pretty easy to print with like PLA. It would also be nice if it could be in color. I have been looking at the T-Glase and the Taulman 645 filament. What of these would best fit my needs? I am printing on the orion. If you have other suggestions just tell me.
Depends on what you mean by strength.
PLA is very hard but tends to crack the nylon variants can be strong vs torsional forces but generally aren't "hard", the majority of them are also a pig to print.
If you can deal with the warping, then for mechanical parts, one of the Nylons is probably your best bet.
I haven't tried Bridge yet, it's supposed to be a lot less difficult to print.
Taulman also actually publish specs for their filament.
Posted: Thu Mar 27, 2014 2:27 am
by Nylocke
*quietly whispers "Ultimachine Polycarbonate"*
Posted: Fri Mar 28, 2014 12:42 pm
by mrbdrm
Nylocke wrote:*quietly whispers "Ultimachine Polycarbonate"*
sadly the orion can't go over 250c
Posted: Fri Mar 28, 2014 12:53 pm
by Nylocke
*whispers "E3d all metal hotend, 300c limited by thermistor"* :P
Posted: Fri Mar 28, 2014 1:05 pm
by guanu
http://seemecnc.com/collections/filamen ... nt-1-spool
lab certified, 4800 psi tensile strength when printed....
Guanu
Posted: Fri Mar 28, 2014 1:35 pm
by printer999
guanu wrote:http://seemecnc.com/collections/filamen ... nt-1-spool
Guanu
What is strongest 645, bridge, or t-glase?
Posted: Fri Mar 28, 2014 2:26 pm
by Nylocke
Not T-Glase, you're basically asking which is stronger, Nylon or Nylon :P
From the 645 page Tensile Strength, Yield 12,428 psi ISO METHOD 527
Bridge says 4800 when printed, of course they aren't both the same nylon, bridge was modified to make it cheaper and easier to print.
Keep in mind the nylon will deform before breaking, considerably more than most filaments
Posted: Fri Mar 28, 2014 6:12 pm
by Eric
What kind of stength? Tensile? Compression? Shear? Torsion? Impact?
Posted: Fri Mar 28, 2014 11:38 pm
by Nylocke
Just think about this, Bridge is a modified nylon polymer that was made for certain properties. Less warp, less moisture absorption, and to be cheaper, thats literally what it says on the page Taulman provides. Tensile wise, the 645 will beat just about anything out of the water, also I couldn't find anything about strength yields for T-Glase, or for bridge other than the 4800 number they provide, and same for the tensile strength of the 645, thats the only data they provide on the material.
Posted: Sat Mar 29, 2014 2:35 am
by enggmaug
probably bc it wouldn't mean anything to give figures wen you don't know how the part will be printed, in term of temperature, layer height, nozzle size, speed, and all those parameters than can influence bonding of layers.
