Hello,
When I try to print 4-6 copies of the parts at the same time, the printer very often stops printing in the middle of the print (all prints via SD card). I red somewhere that upgrading to firmware 0.91 should solve it. I use OSX 10.6.8 and Repetier Host 0.56 - I can via Repetier Host successfully connect to the printer. Within Arduino IDE I selected "Arduino Mega 2560 or Mega ADK" as board and "/dev/tty.usbmodem1d11" as serial board (= the same one I use with Repetier Host). When I try to upload the "eprom_clear" I only get some time out errors. I used the software to update firmware of other 3d printers. The "programmer" is set to "AVR ISP" - Is this the right one for the ORION printer? If yes any suggestions why the upload is not working?
These are the errors showing up:
Binäre Sketchgröße: 1.348 Bytes (von einem Maximum von 258.048 Bytes)
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Upgrade to firmware 0.91 time out error
dinspiration
- Plasticator
Re: Upgrade to firmware 0.91 time out error
Make sure your board is powered buy the PSU and not just USB, the newer version needs to have 12V power to reupload the firmware
dinspiration
- Plasticator
Hello,
I did not remove the board - it is installed in the printer and the printer is switched on. As I wrote I can successfully connect to the printer via repetier host. But when I try to update the firmware I get always these time out errors....
Is the "AVR ISP" the correct programmer?
Is it possible that the eeprom has a kind of write protection enabled?
Nylocke wrote:Make sure your board is powered buy the PSU and not just USB, the newer version needs to have 12V power to reupload the firmware
