calibration without LCD
Posted: Sun Apr 20, 2014 6:58 pm
by whaleboy
I'm going through the manual and am at the calibration step (page 205). This seems to be the only step that uses the LCD controls. I can move the head using the Rep host software, but can't find how to do the step that requires "Set New Z=0.00" from the LCD.
Is it as simple as entering in that line as a command?
Thanks
-David
Re: calibration without LCD
Posted: Mon Apr 21, 2014 4:40 am
by whaleboy
Solved. Made the appropriate LCD cables from an old drive cable. I now have a working LCD and am currently calibrating.
-David
Posted: Mon Apr 21, 2014 10:24 am
by JohnStack
Amazing how that one little thing saves loads of time!
Posted: Fri Apr 25, 2014 8:26 am
by Elysio
I have to refresh the question, because it seems that I will not find very fast a solution for my LCD problem.
So how can I do that with repetier, setting the z : 0.00mm zero point without the LCD?
Thank you in advance. Christoph.
Posted: Fri Apr 25, 2014 8:51 am
by guanu
to set z=0 with repetier host, you want to home the machine, then jog the nozzle down to the bed (very slowly when you get close) and just as the nozzle is about to tap the glass, send M251 S2 to the printer, and that will set z=0.. then home again, and you can run a G1 Z5 F15000 and that should drop it down 5mm above the bed to verify.
Guanu
Posted: Fri Apr 25, 2014 10:48 am
by Elysio
Hi
No it stops ca. 16cm above the bed.
Posted: Fri Apr 25, 2014 10:55 am
by guanu
ah, if thats the case, open eeprom, and set max Z to a larger number to allow it to go down, just be careful and jog it manually down after you do that...
Guanu
Posted: Fri Apr 25, 2014 3:40 pm
by Elysio
Thank this was the right information !
