Feed issues, clicking and eventual grinding
Posted: Wed Apr 23, 2014 1:41 pm
Hey forum! I've been having this issue since this Rostock Max has been under my guardianship, though it's been sometimes better and sometimes worse. I still am not sure what's the root cause.
The hot end has been upgraded to the E3D, but it's having quite regular feed issues. Once it is well calibrated, prints always start out smoothly. Good adhesion to the bed, and it gets the first many layers down fine. But eventually, the extruder motor starts to 'click'. Whenever it does this, the motor's knobbed bolt jumps backwards, and then continues trying to extrude. At first it is clicking backwards less than it's extruding forward, so the net result is still extrusion. If I give the filament a push, it will often overcome whatever the problem is and stop clicking for a bit. But the clicking eventually returns. If I do not do this manual fix, the clicking continues until it has grinded away pretty well the whole filament.
The previous owner advised me that he was having similar issues. He believed that there was too much or too little current going to the extruder motor.
The other possibility is there could be too much friction in the E3D hot end. I have attached some pictures.. whenever it seems to clog, there forms what seems to be a bulge where the filament feeds into the hot end. I'm not sure what is causing this or how to fix it.. I have now disassembled the E3D a few times and rebuilt it, but I'm not sure if I'm getting the torque-ing right.
I can't tell if this is a common problem or not, but it has been recurring constantly for the 3 months or so I have been using this printer. Does anyone else have a similar experience, or any advice that could help?
Thanks for your time!
Chris
I have adjusted in the firmware both 'Extr. 1 PID drive max' and Extr. 1 PID max value [0-255]' to many values between about 150 and 255. In the past this did seem to help, but now it doesn't seem to make any difference.I adjusted in the firmware was the current going to the extruder stepper motor. Too little, and the motor skips steps. Too much, and it grinds away the filament.
Chris
