Why Brass?
Posted: Thu Apr 24, 2014 1:04 pm
I see hotends made from a lot of different materials. Most tips are brass, while the tip/heater/sensor holders are made of aluminum, or stainless steel.
Wouldn't it make more sense to use something with a higher thermal conductivity for the heater/sensor holder, like Copper? C110 Copper is as cheap or cheaper than Brass.
Then I see hotends with cooling fins to keep the heat away from the incoming filament. But they use a thermal conductive material there to be able to dump the heat. Why dump the heat? keep it concentrated in the tip. It seems to me that we're wasting heat. We throw more power at the tip to melt faster to make builds faster, but we dump so much heat.
Why not use a non-thermally conductive material to hold the tip/heater/sensor? Yes this does start to move out of being able to machine a piece of commonly available metal to a different type of material. But with a 3D printer you could print a mold for any anything that could be poured into a mold, dried, and possible fired. Nijna Flex TPE comes to mind for making a mold. Just about any mold-able material can have it's thermal conductivity reduced by adding glass microballons. (I've thought about those in a filament to make it thinker... carbon fiber, and glass microballons... hmm.)
Or why not just coat the whole hot in exhaust ceramic powder for exhaust systems and bake it on. At least you can keep come heat in...
So am I just way over engineering?
