Just Finished Build, Z Axis does not go up, only down
Posted: Fri Apr 25, 2014 8:38 am
Okay, so finished my build last night. It powered up nicely, I got the firmware on there, and used Repetier Host to manually control the printer, as the assembly manual says to do. The X and Y axis move up and down just fine, exciting! The Z axis only moves down. It will not move up. When the Rostock is powered down, the cheapskate moves up & down freely. I reinstalled the firmware on the Rostock to no effect. Could my belts be too tight? A thought went through my mind that perhaps something is wrong with the RAMBO connection for the Z axis motor, and I am considering plugging the motor connector into a different port on the RAMBO. Any ideas?
