Aluminium Plate
Posted: Fri Apr 25, 2014 1:54 pm
by greenlee
Is there a drawing of the Onyx plate available?
I'm looking for something that I can give to a shop to fabricate a aluminium plate for a heat spreader and would like to have the bolt hole drilled as part of the build.
Re: Aluminium Plate
Posted: Fri Apr 25, 2014 2:20 pm
by Jimustanguitar
The dimensions are listed in the details on SeeMeCNC's website. I believe it's 310mm overall with 6 holes at 300mm... Go check for sure, but I think that's what it is.
*edited with exact values*
Re: Aluminium Plate
Posted: Fri Apr 25, 2014 2:25 pm
by greenlee
You are right. Thanks.
310mm Overall diameter
Six 3mm diameter mounting holes spaced on a 300mm diameter pattern
Jimustanguitar wrote:The dimensions are listed in the details on SeeMeCNC's website. I believe it's 300mm overall with 6 holes at 280mm... Go check for sure, but I think that's what it is.
Re: Aluminium Plate
Posted: Fri Apr 25, 2014 3:24 pm
by bubbasnow
a file exists on the forum for the exact shape including the notch at the top needed.
Re: Aluminium Plate
Posted: Fri Apr 25, 2014 4:50 pm
by cambo3d
greenlee wrote:Is there a drawing of the Onyx plate available?
here one I drew up a while ago.. should still be useful.. same one i used to make mine.
heat spreader final dxf.dxf
(195.73 KiB) Downloaded 340 times
