Apostoly's Delayed Build Log
Posted: Fri May 09, 2014 11:39 pm
by apostoly
Hi Guys,
I've been working on my printer whenever i got a chance after work hence why it has taken so long. I made a mistake when soldering the smart LCD connector (I didn't pay close enough attention i guess) and soldered the two 10 prong connectors in the wrong orientation. Part has been ordered from ultimachine already assembled so i can just plug and play when it arrives. I also need to find another spade lug connector as i damaged one of them when trying to remove it from the button
Anyhow, here are all the pics taken from the build process as im sure everyone has seen 1000 times before, thought id follow the trend :D
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_111124.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_111129.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_120155.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_123551.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_170636.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140423_231607.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140424_171715.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140424_171738.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140430_185527.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140430_185538.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140501_191002.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140501_191010.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140502_193602.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140502_193715.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140504_175832.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140504_175840.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140504_175846.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140510_082733.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140510_105257.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140510_120527.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140510_120623.jpg[/img]
Paul.
Re: Apostoly's Delayed Build Log
Posted: Sat May 10, 2014 8:58 am
Some really nice closeups and general pics, some of the best I have seen.
Thanks for posting them and congrats on such a great build.
Posted: Sat May 10, 2014 9:35 am
by gajtguy
hmmm. The black is a nice design.. Thanks for the pics...
Posted: Sat May 10, 2014 6:54 pm
by apostoly
Would anyone know why one of my steppers (Z) makes a lot more noise than the other two.
I have the astrosyns dampeners installed and you can clearly tell on the X and Y axis but when it comes to the Z its still high pitched?
I wiggled the stepper to see if it was loose on the dampener but seems to be good.
Paul.
Posted: Sat May 10, 2014 11:45 pm
Is it possible the Z damper was installed differently than the other two?
I don't even know if it is possible to install them differently but it is one of the few things that make sense.
Posted: Sun May 11, 2014 12:02 am
by gajtguy
How about amount of belt tension? Just a guess.
Posted: Sun May 11, 2014 12:28 am
by apostoly
Eaglezsoar wrote:Is it possible the Z damper was installed differently than the other two?
They are all practically the same on both ends so like you said it doesn't matter how you install them. Well that's what i think anyway..
Ill see how much it annoys me when i actually fire it up. Its probably not tightened on there as well as the other two. I tried pushing it against the frame and it seemed to reduce the noise a little. Ill try to tighten them as best as possible while still assembled.
gajtguy wrote:How about amount of belt tension? Just a guess.
I tightened all the belts not too long ago, that's not the issue im pretty sure.
Posted: Tue May 20, 2014 8:04 am
by apostoly
Got the printer calibrated as best as possible without the LCD..
Pretty happy with the prints to start of with.
Both shrouds were near perfect.
Here are just a couple of snaps of the first prints
Thanks to Joe (joecnc2006) and Mcslappy for helping with the design of the Cam. They work perfectly and will take photos of them installed and a video of it working.
[img]http://i1110.photobucket.com/albums/h45 ... 1396_n.jpg[/img][/URL]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/10258705_10152127857483595_6065487265978676361_o.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/10334473_10152127859613595_8462224145308044333_n.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/1801140_10152127859388595_6439058334066227654_o.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/10153722_10152127859468595_8761651012645183226_n.jpg[/img]
Posted: Tue May 20, 2014 10:03 am
by Tinyhead
Right on! Congrats on the build!
I'm not sure of the construction of the V2, but could that Z-axis stepper be touching the frame anywhere? I would think that if the body of the stepper is still touching, you'd get the whine through the whole machine.
Posted: Tue May 20, 2014 10:35 am
by apostoly
Tinyhead wrote:Right on! Congrats on the build!
Ill have to look into that, need some sleep now though. only 5 hours till i have to go to work... Dam printer is killing my sleeping habits.
Heres another print that just finished.
[img]http://i1110.photobucket.com/albums/h451/apostoly1/10295884_10152128098903595_3851241038307936044_o.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/10295089_10152128098968595_3777777418167829853_o.jpg[/img]
Posted: Sun Jun 01, 2014 4:23 am
by McSlappy
Nice log...
Cool to see the cam printed! And is that a headphone mount? Very cool!
Looks like the whole thing went together pretty well! Congrats on a kickass machine, and I'm further happy that I got black too ;)
Posted: Sun Jun 01, 2014 5:07 am
by apostoly
McSlappy wrote:Nice log...
yea its a headphone mount, it was more of a test print but im gonna end up using it i think haha
black is the way to go, no regrets there
Posted: Sun Jul 13, 2014 6:05 am
by apostoly
Here are some prints over the past few months
This ones fresh off the printer - one of my favorites so far - The antlers were a challenge
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_195454.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_195507.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_195516.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_195535.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_200140.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140705_173648.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140702_205213.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/IMG_20140702_205207.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_130908.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140712_233005.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140712_233034.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140712_233042.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140706_180715.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140622_205307.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140622_205137.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140617_234758.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140619_183105.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140610_182714.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140522_222513.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_193727.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_193737.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_193828.jpg[/img]
[img]http://i1110.photobucket.com/albums/h451/apostoly1/Mobile%20Uploads/IMG_20140713_193836.jpg[/img]
Posted: Sun Jul 13, 2014 6:32 am
Very, Very nice prints!
Thanks for the great pictures!
What slicer do you use the most?
Posted: Sun Jul 13, 2014 7:16 am
by apostoly
Eaglezsoar wrote:Very, Very nice prints!
Thanks Eagle
I find myself using cura the most at the moment, but i do switch between kiss and cura depending on filament type and what im printing.
Took a while to get the hang of how one slicer prints but now i seem to be getting it more and more every print.
Paul
Posted: Sun Jul 13, 2014 8:17 pm
by McSlappy
These look cool! Every since seeing your headphone mount I've been meaning to print one, looks great!
The giraffe is pretty amazing.
