Hi. I'm Nota, and I'm an addict
Posted: Wed May 14, 2014 2:40 pm
I buy too many 3D Printers. (nailed it!)
I currently own a Replicator 2 and a FF Creator X (Received the Rep 2 on 18 March 2014 and the Creator X since the middle of April 2014) and currently have about 400 hours on the Rep 2 and 200 or so on the Creator X, so I obviously like to print.
I also currently have a Rostock Max kit in my shopping cart, ready to order.
I've been reading up on the Rostock Max and came across some, well, not so great reviews but I can't tell if they were recent, or for the V2, or for the original, or if the "reviewer" wasn't completely objective, so I thought I would check in with the forum to introduce myself and ask a few questions. I tried to list each of my initial concerns, and the info I've found to either allay that concern or if I am still a little confused on that item.
Bottom line is: I just want to be prepared for what arrives and adjust my expectations accordingly.
Kit Form:
I am not put off by the printer being in "kit" form since I have dabbled in a little of everything mechanical/electrical/electronic from performing frame-off restorations on motorcycles to building custom, water-cooled computers, car-puters, etc, to installing some pretty wild car stereo installations, so I am reasonably mechanically-inclined, can usually tell a negative lead from a positive lead. Also, I can usually use a soldering iron without setting myself on fire. (that only happened once
Parts requiring additional finishing
I see in the description of the Max V2 that there has been a re-design of the hot-end platform and Delta arms and mounts to eliminate sanding. One of the concerns I saw in the worst of the reviews was that the parts weren't cut at the proper angles so there was a lot of futzing about required to make things fit. Is this still the case? I have about 346,947 Dremel attachments, so I'm not worried if that's the case, I just want to know what I'm in for before it arrives so I can clear an area out in the man cave and set up my work bench with the Dremel Table Router mounts.
EMI/ESD
The Creator X is susceptible to EMI/ESD so I wonder if I can reduce that risk with the Rostock Max. I have about 50ft2 of copper mesh so I can pretty much line the interior of the base to create a Faraday cage to keep interference away, but is the interior able to accommodate the mesh?
Those are my only concerns at present.
Nice to meet you all and I look forward to learning from you guys about the quirks of this weird 3-armed wonder..
Kit Form:
EMI/ESD
