Set Z Height w/o LCD - Possible?
edwardjanderson
- Plasticator
My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Zheight with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
ThatDirectorGuy
Re: Set Z Height w/o LCD - Possible?
Can you use MatterControl to set the Z height?
Z-height should be a component of the EEPROM which you can access from Repetier-Host - config - EEPROMedwardjanderson wrote:My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Zheight with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
I am actually in the exact same position, PID's all done.. Just waiting on parts to arrive so i can connect my LCD panel.If only there was some instructions on how to do itedwardjanderson wrote:My RAMbo LCD interface board is on order (original missing from kit). Is it possible to set the Z height with out the LCD? I am able to tune the extruder and hot bed PIDs from the Repetier-Host -
All good, i did it all manually
thanks
thanks
Yes - MatterControl has EEPROM where you can adjust Z-Height.ThatDirectorGuy wrote:Can you use MatterControl to set the Z height?
