SD uploaded file unreadable on sd reader
Posted: Thu May 29, 2014 5:13 pm
by MarioMas
I tried to modify a old gcode uploaded through repeater to my sd but it look like unformatted/unreadable jam of symbol.
I used notepad, gedit, word and google doc for open it without success.
Any idea?
Re: SD uploaded file unreadable on sd reader
Posted: Thu May 29, 2014 5:52 pm
by DavidF
Why don't you open it in repetier again??
Posted: Sat May 31, 2014 10:02 am
by MarioMas
When i uploaded the gcode repeater can't redownload it; it can only start the sd print.
The strange is this, pc can't read but rambo work
Posted: Sat May 31, 2014 12:03 pm
Repetier by default uses a binary protocol, rather than the original GCode.
When you upload the file from inside repetier host the firmware converts it to this binary form during the upload.
Repetier firmware will read standard GCode files off SDCard, just plug the card into your PC and copy the file that way, it's also a damn site faster.
Posted: Sat May 31, 2014 5:49 pm
by MarioMas
So there is no way to modify the gcode?
Posted: Sat May 31, 2014 6:58 pm
MarioMas wrote:So there is no way to modify the gcode?
Not easily no.
