First Print!
Posted: Thu Jun 05, 2014 9:39 am
by mlapaglia
Finally got the bed's thermistor working and the bed calibrated, decided to print the fan shroud in PLA because the ABS hasn't arrived yet. Even without a layer fan or cleaning the bed the print came out fine
Still need to work on some overhang issues but the stringing is non-existent.
Thanks to the motor dampers and soborothane pads I can't tell it's running when I walk out of the room!
https://www.youtube.com/watch?v=p07lxaPDSnE#t=229
Re: First Print!
Posted: Thu Jun 05, 2014 11:01 am
Your machine looks good and is very quiet when compared to other printers. Good job!
Re: First Print!
Posted: Thu Jun 05, 2014 9:04 pm
by Tinyhead
Just watching the video reminds me why I moved away from Slic3r... sweet jesus the retracts.
Eagle is right though - The machine sounds nice and quiet. And the print looks amazing. You're lucky you don't get the stringing.
Re: First Print!
Posted: Thu Jun 05, 2014 10:21 pm
by mlapaglia
I've got it retracting 10mm at 50mm/s , seems to be working fine for PLA, might try lowering the distance down to get things moving a bit quicker.
Re: First Print!
Posted: Fri Jun 06, 2014 12:32 am
by Tinyhead
mlapaglia wrote:I've got it retracting 10mm at 50mm/s , seems to be working fine for PLA, might try lowering the distance down to get things moving a bit quicker.
Yeah, I would lower it down. 10mm is pretty excessive. Personally I would start at about 5 and work your way down. I think I run at 3mm at 30mm/s.
A few of the very experienced printers on here say that it's the retraction speed that is more critical than anything, and that quicker is not always better.
Re: First Print!
Posted: Fri Jun 06, 2014 3:41 am
by McSlappy
Yeah 10mm is huge. I do 2mm at 15mm/s which is probably too slow, but I'm cautious running PLA now
with my e3d v5. I could probably double that speed now that I'm using oil with PLA.... I will next time
