[SOLVED]Rostock MAX V2 X,Y,Z Steppers dont move
Posted: Fri Jun 13, 2014 11:57 am
just finished build, have checked everything - everything works, except X,Y,Z steppers.
I press Home in RH, in LCD menu, i press +x, -x, +y, -y, +z, -z, nothing happens. Extruder stepper works great. Settings i have done looks like is equal to ones in manual (it's great), except i have changed baudrate to 115.smth everywhere to make Rostock visible by RH. For this i have changed settings in LCD menu and saved them to EEPROM, now it looks that way:
maybe problem is here, may be it is not here, i don't know
<?xml version="1.0" encoding="utf-8"?><Repetier-Firmware-EEPROM>
<epr pos="75" type="2" value="115200">Baudrate</epr>
<epr pos="129" type="3" value="0.000">Filament printed [m]</epr>
<epr pos="125" type="2" value="0">Printer active [s]</epr>
<epr pos="79" type="2" value="1800000">Max. inactive time [ms,0=off]</epr>
<epr pos="83" type="2" value="0">Stop stepper after inactivity [ms,0=off]</epr>
<epr pos="11" type="3" value="80.0000">Steps per mm</epr>
<epr pos="23" type="3" value="300.000">Max. feedrate [mm/s]</epr>
<epr pos="35" type="3" value="120.000">Homing feedrate [mm/s]</epr>
<epr pos="39" type="3" value="35.000">Max. jerk [mm/s]</epr>
<epr pos="133" type="3" value="0.000">X home pos [mm]</epr>
<epr pos="137" type="3" value="0.000">Y home pos [mm]</epr>
<epr pos="141" type="3" value="0.000">Z home pos [mm]</epr>
<epr pos="145" type="3" value="250.000">X max length [mm]</epr>
<epr pos="149" type="3" value="250.000">Y max length [mm]</epr>
<epr pos="153" type="3" value="234.660">Z max length [mm]</epr>
<epr pos="59" type="3" value="1850.000">Acceleration [mm/s^2]</epr>
<epr pos="71" type="3" value="3000.000">Travel acceleration [mm/s^2]</epr>
<epr pos="881" type="3" value="269.000">Diagonal rod length [mm]</epr>
<epr pos="885" type="3" value="130.250">Horizontal radius [mm]</epr>
<epr pos="891" type="1" value="80">Segments/s for travel</epr>
<epr pos="889" type="1" value="225">Segments/s for printing</epr>
<epr pos="893" type="1" value="0">Tower X endstop offset [steps]</epr>
<epr pos="895" type="1" value="0">Tower Y endstop offset [steps]</epr>
<epr pos="897" type="1" value="0">Tower Z endstop offset [steps]</epr>
<epr pos="901" type="3" value="210.000">Alpha A(210):</epr>
<epr pos="905" type="3" value="330.000">Alpha B(330):</epr>
<epr pos="909" type="3" value="90.000">Alpha C(90):</epr>
<epr pos="913" type="3" value="0.000">Delta Radius A(0):</epr>
<epr pos="917" type="3" value="0.000">Delta Radius B(0):</epr>
<epr pos="921" type="3" value="0.000">Delta Radius C(0):</epr>
<epr pos="808" type="3" value="39.910">Z-probe height</epr>
<epr pos="812" type="3" value="2.000">Z-probe speed</epr>
<epr pos="840" type="3" value="150.000">Z-probe x-y-speed</epr>
<epr pos="800" type="3" value="0.000">Z-probe offset x</epr>
<epr pos="804" type="3" value="0.000">Z-probe offset y</epr>
<epr pos="816" type="3" value="100.000">Z-probe X1</epr>
<epr pos="820" type="3" value="20.000">Z-probe Y1</epr>
<epr pos="824" type="3" value="160.000">Z-probe X2</epr>
<epr pos="828" type="3" value="170.000">Z-probe Y2</epr>
<epr pos="832" type="3" value="20.000">Z-probe X3</epr>
<epr pos="836" type="3" value="170.000">Z-probe Y3</epr>
<epr pos="880" type="0" value="0">Autolevel active (1/0)</epr>
<epr pos="106" type="0" value="1">Bed Heat Manager [0-3]</epr>
<epr pos="107" type="0" value="255">Bed PID drive max</epr>
<epr pos="124" type="0" value="80">Bed PID drive min</epr>
<epr pos="108" type="3" value="87.860">Bed PID P-gain</epr>
<epr pos="112" type="3" value="3.010">Bed PID I-gain</epr>
<epr pos="116" type="3" value="641.820">Bed PID D-gain</epr>
<epr pos="120" type="0" value="255">Bed PID max value [0-255]</epr>
<epr pos="200" type="3" value="92.400">Extr.1 steps per mm</epr>
<epr pos="204" type="3" value="100.000">Extr.1 max. feedrate [mm/s]</epr>
<epr pos="208" type="3" value="45.000">Extr.1 start feedrate [mm/s]</epr>
<epr pos="212" type="3" value="6500.000">Extr.1 acceleration [mm/s^2]</epr>
<epr pos="216" type="0" value="1">Extr.1 heat manager [0-3]</epr>
<epr pos="217" type="0" value="205">Extr.1 PID drive max</epr>
<epr pos="245" type="0" value="60">Extr.1 PID drive min</epr>
<epr pos="218" type="3" value="31.3600">Extr.1 PID P-gain/dead-time</epr>
<epr pos="222" type="3" value="2.1800">Extr.1 PID I-gain</epr>
<epr pos="226" type="3" value="112.9000">Extr.1 PID D-gain</epr>
<epr pos="230" type="0" value="255">Extr.1 PID max value [0-255]</epr>
<epr pos="231" type="2" value="0">Extr.1 X-offset [steps]</epr>
<epr pos="235" type="2" value="0">Extr.1 Y-offset [steps]</epr>
<epr pos="239" type="1" value="3">Extr.1 temp. stabilize time [s]</epr>
<epr pos="250" type="1" value="150">Extr.1 temp. for retraction when heating [C]</epr>
<epr pos="252" type="1" value="0">Extr.1 distance to retract when heating [mm]</epr>
<epr pos="254" type="0" value="255">Extr.1 extruder cooler speed [0-255]</epr>
<epr pos="246" type="3" value="0.000">Extr.1 advance L [0=off]</epr>
</Repetier-Firmware-EEPROM>
