Harblar made a Dark TARDIS (v2)
Posted: Wed Jul 23, 2014 12:20 pm
Hey All!
Been meaning to make a build thread since my kit arrived, but got distracted building it and am just now getting around to uploading the photos and whatnot. hahaha
Anyway, why Dark Tardis? Well, I've already had several people ask me if it was a time machine or something and since it kind of resembles something out of Dr Who (only meaner) I thought, why not. Good name for it!
On to some build photos!
[img]https://lh4.googleusercontent.com/-A1nQ ... C01780.JPG[/img]
I wasn't going to paint the parts originally, but saw how others builds turned out painted, and since all the parts were already masked so nicely I figured what the hell. Always liked the red on black combo.
As you can see I got the base started in this shot. You may also have noticed, 4 steps in and I've already got a mod! I was going to use the power supply that came with the kit, but I just happened to have a brand new OCZ 700 Watt Modular Power Supply sitting in my closet taking up space and in the famous words of Tim Allen, "More Power!!! ARR ARR ARR!!!"
[img]https://lh4.googleusercontent.com/-oSqL ... C01783.JPG[/img]
The PS had two separate 12v rails (cant remember how many amps per rail offhand, but it was plenty) so I split them up between the heating elements and everything else. Had a couple extra wires from the one connector I sued for the second rail, so I just shrink wrapped the ends to protect against any accidental shorts.
[img]https://lh5.googleusercontent.com/-U0vD ... C01784.JPG[/img]
Got a Rev 6 Hot plate. Wired it up very similar to the the Rev 5 in the manual and then covered it up in all that fancy Kapton Tape.
[img]https://lh3.googleusercontent.com/-pPlU ... C01785.JPG[/img]
Here's the LEDs. Could have sworn I soldered them both the same way (long Lead on the positive plate), but for whatever reason the Bed LED won't light. Not a huge deal since a quick glance at the LCD screen will tell me whether or not the bed is hot, but my OCD is kinda nagging me about it. Might have to do some more investigating. The hell of it is I got my bed really level right now and don't really want to touch it and risk screwing that up!
[img]https://lh4.googleusercontent.com/-KPq9 ... C01786.JPG[/img]
All mounted up!
[img]https://lh6.googleusercontent.com/-2AJu ... C01787.JPG[/img]
From here on out the detail images get a little sparser. It was hotter than hell out this weekend and the shop doesn't have AC. I was sweating and tired and didn't feel like taking a lot of pictures.
Towers wired and up. Saw someone else mention that the next revision manual should say how much wire to have stick out of either end. Good suggestion ( I ended up having to pull the wire one way or the other in two towers after they were installed myself), but instead of trying to measure it out and be precise with it An easier way would be to say: For the Tower containing the Hot end and fan wiring, pull enough wire through to reach back past the end (bottom) of the tower. For the Extruder motor wires, pull about 6 inches. For the Endstop wires, don't worry about it... they pull easy and safely even with the tower installed.
[img]https://lh6.googleusercontent.com/-Qtkj ... C01789.JPG[/img]
This is how I have all my wires routed on the top, more or less. I did a little tweaking after splicing in the extruder, but the end result is none of the wire groups cross or come close to any of the endstop wires and, so far, I haven't seen a hint of any abnormal behavior from them.
[img]https://lh6.googleusercontent.com/-XQYY ... C01790.JPG[/img]
At this point I was fairly confident that I'd be spending the next week and a half with the ammeter trying to figure out what wire went where. In reality it only took an hour or so and one or two uses of the meter to get it all hooked up. a roll of scotch tape and sharpie saves a ton of headache down the road. Pull a group of wires and immediately label them. Makes Life Easy!
[img]https://lh4.googleusercontent.com/-BuQm ... C01794.JPG[/img]
Hotend installed and wired up. I've got some better pics of the hot end itself on my iPhone I'll have to upload later. Not to brag, but I did a pretty damn good job of putting it together (at least I think so anyway. time will tell hahaha). It looks very close to the manual and is relatively clean. I bet I only need 2-3 square inches of paper towel to clean up after I was done. The trick I used was to poke a fairly small hole in the nozzle of the RTV tube so I could squeeze it out in a relatively thin bead. I then start applying it just above the resistor on the wire while slowly spinning the resistor and working my way down with the RTV. Basically turning the resistor into a barber pole. I takes a pretty healthy squeeze on the RTV tube, but the end result is worth it. Once it looks like the resistor in the manual, carefully stick it into the Hotend and fill in the gaps. The small hole really helps with maintaining precision.
[img]https://lh3.googleusercontent.com/-T_jH ... C01795.JPG[/img]
Extruder mounted. (I swear I only mounted it backwards once! haha)
[img]https://lh5.googleusercontent.com/-tiR2 ... C01796.JPG[/img]
Getting closer. All I got left is the final wiring...
... Which I don't have any photos of!
[img]https://lh5.googleusercontent.com/-GlDO ... C01798.JPG[/img]
Finished! And to my total amazement, nothing blew up or started on fire when I turned on the power!
[img]https://lh6.googleusercontent.com/-c-dw ... C01799.JPG[/img]
[img]https://lh4.googleusercontent.com/-I-np ... C01802.JPG[/img]
After installing the software I discovered the hotend wasn't working. Turns out the wires had pulled lose from the rambo while mounting the board. Quick Fix.
[img]https://lh5.googleusercontent.com/-EuOY ... C01804.JPG[/img]
As you can see I also built myself a nice little stand out of some used bathroom cabinets I had laying around. Makes a great workspace. Plenty of room for storing tools and filament and nice work area for my laptop!
(and of course, it's on wheels so it's easy to move around)
I had a few issues with my first print (mostly due to the fact that it was 11pm and I'd forgotten to buy any of the Disappearing purple glue sticks! doh!) Anyway, I was able to get a few layers to print before it broke loose from the glass. enough to satisfy my curiosity anyway.
Yesterday morning I went out and got the right stuff and (using the preset abs files for Slic3r I got from SEEME CNC's website) I got this!
[img]https://lh4.googleusercontent.com/-pjmg ... C01806.JPG[/img]
[img]https://lh4.googleusercontent.com/-m4lD ... C01807.JPG[/img]
[img]https://lh4.googleusercontent.com/-VH-u ... C01808.JPG[/img]
[img]https://lh4.googleusercontent.com/-r7-v ... C01810.JPG[/img]
The fit is a little snug, but not bad. The quality of the print came out really well. The first layer seems to be going down really flat.
I installed the fan, only to find out that I can't get the fan to work... Grrrr... Not sure if it's the fan, the wiring to the rambo board, or a software issue. I'm going to check it with the PS I didn't use and seem if that'll spin it. if it's just the fan not working, then I'm going to print the 40 mm shroud and put in a better fan!
Onto part two! This one I designed myself.
(it also took two tries to get right, but I'll get to that in a sec.)
[img]https://lh3.googleusercontent.com/-ctKl ... C01811.JPG[/img]
[img]https://lh4.googleusercontent.com/-wByi ... C01812.JPG[/img]
These are knobs for my oven. The original knobs broke several years ago and we've been using a pair of pliers ever since. Well, no more!
Now, the reason I had to print them twice was due to my own fault and a printer/software/physics issue.
First off, I screwed up the Slic3r settings and accidentally had the infill set to 0! *facepalm
Secondly, the model I designed was lower poly count than I wanted and ended up being faceted for a round knob. Blah.
And Third, the dimensions, as printed, were off from what I had designed, so it didn't fit on the post.
[img]https://lh4.googleusercontent.com/-aLTF ... C01813.JPG[/img]
First attempt on the left, second on the right.
[img]https://lh5.googleusercontent.com/-FjFY ... C01814.JPG[/img]
[img]https://lh4.googleusercontent.com/-oZ7j ... C01816.JPG[/img]
To get to the second print I increase the poly count in the stl (80 MB file!
It took a bit to load, slice, and print, but it came out nice!) and scaled it up by 1.062. This made the overall size bigger than planned, but the post hole now fits (all be itvery tight, which I suppose isn't a bad thing)
Well... That's about all I've got for now. I obviously have more calibrations that need to be done to improve the accuracy of the printed objects. I've also got to trouble shoot the PEEK fan.
Which also reminds me... In troubleshooting the fan last night I managed to short the wire while trying to see if it was getting power and blew on of those little rice grain fuses on the rambo board... Anybody know what size replacement i need and where I could source them locally? Radioshack, perhaps?
Thanks! Hope you enjoyed my long winded, pic heavy, build thread. More to come, I'm sure!
All mounted up!
