Calibration Issue
Posted: Thu Aug 07, 2014 7:52 pm
I just received my Orion printer and the first 3 parts seemed to print reasonably well. Then the quality feel off quickly and it failed the last 3 attempts due to the hot head scraping the parts off the bed.
I went through the calibration procedure
1) Set Z height in advanced settings.
2) Went through the calibration procedure multiple times
a) Each time the hot head came down and touched the glass at the center (rather the 2mm up)
b)Extruder was too high at the X and Y axes stops
c)Extruder was low (with the extruder hitting the glass plate during the transition) at the Z axis. I have the adjustment screw for the Z axis all the way in, so there is no further adjustment there.
I would appreciate any suggestions. Thanks - Hank
