Mounting a JHead to the standard effector
Posted: Thu Aug 21, 2014 10:05 am
by Hansen
Hi all
I just bought myself a JHead hot end, and now I am completely confused about the best mount to print for the hot end. I want it to fit the standard effector on the Rostock Mac V2. A mount for a PEEK fan (preferable matching the standard PEEK fan supplied with the printer) would be nice too. Can any of you guys point me to these mounts somewhere?
Hansen
Re: Mounting a JHead to the standard effector
Posted: Thu Aug 21, 2014 10:07 am
by guanu
so you need something like http://seemecnc.com/collections/parts-a ... t-hot-ends hmmmmm, where to get one, where to get one... nope, no idea, think yer stuck with designing something ;)
Guanu
Posted: Thu Aug 21, 2014 10:51 am
by Hansen
Mmmm, I've found several JHead mounts, but I am not sure they fit the RMV2 effector. I like this because of the simplicity, but I just can't see how I would mount it (does it fit, or it is designed for another effector?):
http://www.thingiverse.com/thing:253859
Given the number of different mounts... what am I doing different than everybody else? Do people make new effectors too?
Posted: Thu Aug 21, 2014 11:09 am
Hansen wrote:Mmmm, I've found several JHead mounts, but I am not sure they fit the RMV2 effector. I like this because of the simplicity, but I just can't see how I would mount it (does it fit, or it is designed for another effector?):
Several of the mounts from Thingiverse will work but very few have a place for a peek fan and which one to choose is difficult.
This one works and has a place for a fan although you will need to buy the 30mm fan. I don't think it comes with the fan.
http://www.tricklaser.com/J-Head-Groove ... JHGMNT.htm
Posted: Fri Aug 22, 2014 9:00 am
I use the TrickLaser J-Head mount myself and it's very nice.
Posted: Fri Aug 22, 2014 12:01 pm
by Jimustanguitar
I also have used the TL mount. Brian makes great stuff!
Another one to keep on the radar will be the YellowJacket from my hometown makerspace! Glenn has been working on the design for a while, and his production batch of boards just came in!
[img]https://fbcdn-sphotos-f-a.akamaihd.net/ ... bd8147f4ab[/img]
http://makerhive.proboards.com/thread/1 ... otend-plug
Posted: Fri Aug 22, 2014 4:07 pm
by bvandiepenbos
I saw Glenn's board at last nights meeting... really nice design. Makes a clean install. Easy to unplug and swap out heads if you want.
The board is thick enough to take the place of the stock platform.
Works with a SeeMe hot-end or a groove mount hot-end.
Also has a place to mount a fan.
Posted: Fri Aug 22, 2014 6:30 pm
Jimustanguitar wrote:I also have used the TL mount. Brian makes great stuff!
Would you inform us when they are ready for sale?
Posted: Sun Aug 24, 2014 4:11 pm
Is there a photo of it with the connectors soldered on, but no hot end installed?
Also, "SQUEEEEEE!" *ahem*
Posted: Sun Aug 24, 2014 4:14 pm
geneb wrote:Is there a photo of it with the connectors soldered on, but no hot end installed?
I swear you are starting to lose it!
Posted: Sun Aug 24, 2014 5:36 pm
by Mac The Knife
It's all that flavoured coffee he's been consuming,,,,,,
Posted: Sun Aug 24, 2014 7:41 pm
*slow clap*
(Eagle, you must have it in order to lose it! :D )
Posted: Sat Aug 30, 2014 10:13 am
by DavidF
I just made a Jhead mount. Try it out and see if it works for you.[img]http://i1102.photobucket.com/albums/g446/davidflowers1/utf-8BSU1BRzA3OTMuanBn.jpg[/img]
jmount top.stl
(488.77 KiB) Downloaded 443 times
jmount top.stl
Posted: Sat Aug 30, 2014 11:01 am
by DavidF
Maybe someone will find it helpful...
Posted: Thu Sep 18, 2014 12:39 pm
by Jimustanguitar
No, but here are some better images.
[img]http://i.imgur.com/cl2iwcw.png[/img]
[img]http://i.imgur.com/foB2hci.png[/img]
[img]http://i.imgur.com/BQLopjg.png[/img]
[img]http://i.imgur.com/UuHasSx.png[/img]
Posted: Thu Sep 18, 2014 5:08 pm
Those would be great if they ever go up for sale.
Posted: Mon Sep 22, 2014 1:06 pm
by Jimustanguitar
Eaglezsoar wrote:Would you inform us when they are ready for sale?
http://www.themakerhive.com/shop/viewit ... oductid=18
They're up for sale as of this morning, enjoy!
Posted: Mon Sep 29, 2014 10:38 pm
by 626Pilot
Pretty sure my E3D mount will work fine since E3Ds and J-heads use the same mount. http://www.thingiverse.com/thing:137140
Posted: Tue Sep 30, 2014 5:29 am
Just ordered two of these and plan on buying some more.
Thanks for referring us to these!
Posted: Thu Dec 25, 2014 11:07 am
by RegB
{Not STRICTLY J-head related}
I got three of Glenn's quick connect boards just before the holiday,
along with the trick trucks upgrade. I might as well destroy everything all at once (-:
Anyhow, it turned out that on MY original hot end the cold end part isn't threaded
down far enough to allow me to use just the melamine spacer and circuit board,
I either need another spacer or a few thick washers.
Alternatively I could space it on top like Jim did, but I think that would need longer screws
and various other spacer bits.
Hmmm, I tend to over-tighten things too, tractor size wrench handling will do that to Ya.
The hardware stores seem to be closed today - ain't that odd ?
Posted: Thu Dec 25, 2014 3:07 pm
by barry99705
RegB wrote:{Not STRICTLY J-head related}
You'd think they'd be open today. Would make a killing on the emergency batteries for toys sales.
Posted: Thu Dec 25, 2014 9:35 pm
by RegB
Now TOTALLY unrelated to J heads...
A sudden discovery of head lice at my daughter's house today certainly helped the local pharmacy keep the lights on.
Tons of clothes, bedding and soft toys to wash and dry, so the laundromat made out too.
Back towards the topic; The pictures of Jim's solution are on the makerhive web site and I think I will be mounting mine
a very similar way. I am rebuilding the SeeMeCNC hot end with a pair of 20 watt cartridge heaters and the extra space
will give me a bit more space to work in. To ME this is very small work, so opening it up a little helps.
Posted: Thu Dec 25, 2014 10:33 pm
by jdurand
Dr Bronner's Peppermint liquid soap will clear those lice up. The Peppermint oil kills them.
Posted: Tue Dec 30, 2014 4:02 pm
by RegB
I got three of them - a week or so ago, but time pressures have been upon me....
Since I am not a member on the makerhive I'll ask here;
{My only rationale is that I don't join anything that REQUIRES my DoB.}
{Too much other info becomes available from too many other places once that is revealed.}
Did you use multiple pins for power and ground on the big black plug ?
If so how did you do that ? i.e. the one to many split.
PS What crimp tool for the tiny pins ?
I may have to grind my radio shack crimper almost in half for the small ones, or upgrade.
It seems the ones on the strip are for the small white plugs and the 15 or so separated ones are for the big black plug.
BTW - - I HATE having to crimp things.
I've never trusted crimps with hand tools, though I acknowledge that they are in many ways the best choice when done PROPERLY, especially when done predictably by machines.
